Einleitung
Screen and / or digitizer are broken but the rest of the phone is still fully functional.
Was du brauchst
With the help of a silicone spatula or similar opening tool, press gently into the separation between housing and screen
Gently pry the frame away from the screen .
Disconnect the rest of all the connectors. (Image shows fingerprint scanner connector already removed)
First disconnect the connector for the fingerprint scanner
Then carefully pry the scanner (it is adhered to the board )
Preheating the scanner area with a hair dryer can help
Remove the plastic cover from the top of the phone
Gentle prying may be help to loosen it.
Remove the screw hidden under the cover.
Disconnect the ribbon cable
Remove the screw.
Carefully remove the circuit board
Remove the upper speaker
Caution: When removing the speaker, the two parts of the speaker can separate from each other. They are only held together by two very thin copper cables!
The best way to get to the bottom of the speaker and pry it out carefully is by using the direction of the red arrow.
Peel off the two battery adhesive strips to remove the battery
Pull as flat as possible and rather slowly. Heating the display with a hair dryer makes the whole thing a little easier.
Disconnect the ribbon cable for the charging board. Keep it safe for later reuse.
Depending on the completeness of the replacement part, the LED lighting may also be removed
T o remove it, gently pry with some pointed tweezers or similar tool
For testing purposes, the button bar, the screen and the battery can be connected.
Attention! When doing so, there is an increased risk of damaging the connections or the battery. Be very careful!
A long press on the bottom button should start the phone
If previously removed, insert the LED bar (red circle)
Insert the charging board into proper position and tighten (blue circle)
Remove the blue protective strip from the corresponding adhesive surface. Insert the ribbon cable into the power supply
Press the cable flat onto the adhesive area
Ensure everything is properly aligned
Insert the motherboard
Use the metal pin and the plastic hook to check proper alignment.
Remove the cover from the two adhesive strips for the battery
Insert the battery and reconnect it.
Press the fingerprint scanner back into its position.
Press the display back into the housing. Done!
Repeat the steps in reverse order to reassemble your device.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
3 Kommentare
Watch and pray ,global warming.
