Zum Hauptinhalt wechseln
Remington S5500 Ceramic Plate Removal
Was du brauchst
  1. Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: Schritt 1, Bild 1 von 3 Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: Schritt 1, Bild 2 von 3 Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: Schritt 1, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove the 3 screws holding the black plastic cover in place.
    • Pull upwards and remove the black plastic cover.
    • Remove the ceramic plate by pulling the plate parallel to the straightener, while pulling upwards.
  2. Remington S5500 Ceramic Plate Removal: Schritt 2, Bild 1 von 3 Remington S5500 Ceramic Plate Removal: Schritt 2, Bild 2 von 3 Remington S5500 Ceramic Plate Removal: Schritt 2, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove the 3 screws holding the black plastic cover in place. The screws are located in the same places as the other side.
    • Remove the two screws off of the chip using a Phillips #1 screwdriver.
    • Pull off the chip with the same method as the black plastic cover.
  3. Remington S5500 Ceramic Plate Removal: Schritt 3, Bild 1 von 2 Remington S5500 Ceramic Plate Removal: Schritt 3, Bild 2 von 2
Abschluss
Benjamin Yohe
303 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G3, Wilson Summer 2018 Mitglied von IUPUI, Team S3-G3, Wilson Summer 2018
IUPUI-WILSON-SU18S3G3
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 54
Insgesamt: 2,417
