Zum Hauptinhalt wechseln
Removal/Replacement of Dell Inspiron E1705 Hard Drive
Was du brauchst
  1. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Battery: Schritt 1, Bild 1 von 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Removal/Replacement of Dell Inspiron E1705 Hard Drive: Schritt 2, Bild 1 von 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive: Schritt 2, Bild 2 von 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: Schritt 3, Bild 1 von 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: Schritt 3, Bild 2 von 2
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Removal/Replacement of Dell Inspiron E1705 Hard Drive: Schritt 4, Bild 1 von 1
    • Slide the hard drive tray out of the hard drive compartment.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 22-5, Maness Fall 2010 Mitglied von Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 24
Insgesamt: 20,440
