Einleitung
Remove the main fan from the case.
Was du brauchst
Pull on outer latch.
Lower door until it is level with your work surface.
Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
Fast fertig!
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
