Zum Hauptinhalt wechseln
Remove and clean the Whirlpool dishwasher spray arm
Was du brauchst
  1. Remove and clean the Whirlpool dishwasher spray arm, Spray arm: Schritt 1, Bild 1 von 2 Remove and clean the Whirlpool dishwasher spray arm, Spray arm: Schritt 1, Bild 2 von 2
    • Turn off the dishwasher.
  2. Remove and clean the Whirlpool dishwasher spray arm: Schritt 2, Bild 1 von 3 Remove and clean the Whirlpool dishwasher spray arm: Schritt 2, Bild 2 von 3 Remove and clean the Whirlpool dishwasher spray arm: Schritt 2, Bild 3 von 3
    • Remove the lower rack.
  3. Remove and clean the Whirlpool dishwasher spray arm: Schritt 3, Bild 1 von 1
    • Locate the lower spray arm.
  4. Remove and clean the Whirlpool dishwasher spray arm: Schritt 4, Bild 1 von 3 Remove and clean the Whirlpool dishwasher spray arm: Schritt 4, Bild 2 von 3 Remove and clean the Whirlpool dishwasher spray arm: Schritt 4, Bild 3 von 3
    • Detach the lower spray arm by rotating the base counterclockwise.
  5. Remove and clean the Whirlpool dishwasher spray arm: Schritt 5, Bild 1 von 3 Remove and clean the Whirlpool dishwasher spray arm: Schritt 5, Bild 2 von 3 Remove and clean the Whirlpool dishwasher spray arm: Schritt 5, Bild 3 von 3
    • Detach the top spray arm by rotating the base clockwise.
  6. Remove and clean the Whirlpool dishwasher spray arm: Schritt 6, Bild 1 von 2 Remove and clean the Whirlpool dishwasher spray arm: Schritt 6, Bild 2 von 2
    • Clean the spray arm with warm soapy water and a soft brush.
  7. Remove and clean the Whirlpool dishwasher spray arm: Schritt 7, Bild 1 von 3 Remove and clean the Whirlpool dishwasher spray arm: Schritt 7, Bild 2 von 3 Remove and clean the Whirlpool dishwasher spray arm: Schritt 7, Bild 3 von 3
    • Rinse thoroughly and reattach the spray arm to the dishwasher.
    • The longer spray arm goes on the bottom and the shorter one on the top.
  8. Remove and clean the Whirlpool dishwasher spray arm: Schritt 8, Bild 1 von 1
    • Run a cycle with hot water and a dishwasher cleaner to further clean the interior.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
York University, Team N-9, Morris Winter 2023 Mitglied von York University, Team N-9, Morris Winter 2023
YORK-MORRIS-W23SNG9
2 Mitglieder
2 Anleitungen geschrieben
2 Kommentare zur Anleitung
This is fine for light soil, but if you let the two filters in the bottom of the washer get impeded by slime and food debris, the arms will have food particles inside them and the finer holes of "premium" washers are too small to reverse flush. Any added features in them will make things worse. Soaking in a solution of warm, not hot water with liquid enzyme drain cleaner for several nights may digest the protein and fat and let them pass.
P Schmied - Antwort
Thanks or this post. I'm facing this exact problem, upper spray arm holes are clogged with maybe pieces of labels and I can't clear it. I'll try your method.
Rick Cahoon -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 21
Letzte 7 Tage: 129
Letzte 30 Tage: 597
Insgesamt: 11,382
