Zum Hauptinhalt wechseln
Remove the Screen
Was du brauchst
  1. Remove the Screen, Remove Screws: Schritt 1, Bild 1 von 3 Remove the Screen, Remove Screws: Schritt 1, Bild 2 von 3 Remove the Screen, Remove Screws: Schritt 1, Bild 3 von 3
    • Remove the screws from the bottom, right, and left side of camera.
  2. Remove the Screen, Remove back: Schritt 2, Bild 1 von 1
    • Remove the back of the camera, this may require force.
  3. Remove the Screen, Remove Metal Bracket: Schritt 3, Bild 1 von 1
    • Unscrew the right metal bracket of the viewing lens
  4. Remove the Screen, Remove front of camera: Schritt 4, Bild 1 von 1
    • Unscrew the top right corner screw
  5. Remove the Screen: Schritt 5, Bild 1 von 1
    • Unscrew the bottom right corner screw.
  6. Remove the Screen: Schritt 6, Bild 1 von 2 Remove the Screen: Schritt 6, Bild 2 von 2
    • Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
  7. Remove the Screen: Schritt 7, Bild 1 von 2 Remove the Screen: Schritt 7, Bild 2 von 2
    • Pull the front of the camera off of the mother board.
  8. Remove the Screen, Remove the Screen: Schritt 8, Bild 1 von 1
    • Unhinge the outer case of the screen from the back of the camera. The screen should still be hanging by wires.
  9. Remove the Screen: Schritt 9, Bild 1 von 1
    • Remove outer case/rim of screen from the back of the camera. The screen should still be hanging by the red wire and white wire.
  10. Remove the Screen: Schritt 10, Bild 1 von 1
    • Pull out the red wire and white wire attaching the screen to the motherboard.
  11. Remove the Screen: Schritt 11, Bild 1 von 1
    • Flip up black lever holding data cable to motherboard, and remove data cable from motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Melissa
240 Reputation
2 Anleitungen geschrieben
Ohio State, Team 1-2, Buehl Spring 2013 Mitglied von Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 17
Insgesamt: 382
