Einleitung
Remove the motherboard case to expose the free-floating platform, motors, and tubing beneath.
Was du brauchst
Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
Insert a Phillips #1 screwdriver through the screw holes.
Unscrew the two 9.7 mm screws.
First pull up, then pull down on the spring to detach it from the hooks.
Lift up on the motherboard case and pull it forward to remove it from the device. This will expose the free-floating platform, as well as motors, water tubing, and the magnetic sensor pads.
3 Kommentare
Etape 14 ...... poubelle !
Etape 12 .................................. Poubelle !
Can you add more detail? We have disconnected and reconnected the spring multiple times. What was the tricky part?
