Einleitung
In order to perform any sort of repair on the throttle body unit, it must first be removed from the engine by following these step by step instructions
Was du brauchst
Firstly Disconnect battery
Always take the negative terminal off first.
'''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
Locate the two hoses on the top of the throttle body.
Gently lift the hoses off.
Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
Locate throttle linkage arm.
Open the locking clip with a flat head screwdriver.
Pry off the linkage arm with a flat head screwdriver.
Locate the three 13mm nuts attaching the throttle body to the intake manifold.
Remove nuts with a 13mm crescent wrench.
Lift the throttle body off of the intake manifold.
The manifold is now out of the engine bay and ready for cleaning or adjustment.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
