Zum Hauptinhalt wechseln
Removing Back Cover
Was du brauchst
  1. Removing Back Cover, Removing Back Cover: Schritt 1, Bild 1 von 3 Removing Back Cover, Removing Back Cover: Schritt 1, Bild 2 von 3 Removing Back Cover, Removing Back Cover: Schritt 1, Bild 3 von 3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Removing Back Cover: Schritt 2, Bild 1 von 2 Removing Back Cover: Schritt 2, Bild 2 von 2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Removing Back Cover: Schritt 3, Bild 1 von 3 Removing Back Cover: Schritt 3, Bild 2 von 3 Removing Back Cover: Schritt 3, Bild 3 von 3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Removing Back Cover: Schritt 4, Bild 1 von 1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Removing Back Cover: Schritt 5, Bild 1 von 1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
Hasit
195 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 6-17, Maness Spring 2010 Mitglied von Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 4,306
