Einleitung
This guide will show you how to remove the CCFL tubes from the CCFL assembly.
Was du brauchst
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Suction Cups (Pair)$16.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
To fully detach the bezel: disconnect the microphone cable connector, removing tape as necessary.
To keep it attached, leave the microphone cable attached to the logic board, and place the bezel 'above' the chassis, with the microphone cable forming a hinge.
be sure to tuck the microphone cable and connector into the void next to the camera board.
Gently guide the microphone connector and cables through the ±1in long slot at the right of the iSight camera. Once the bezel is properly assembled, gently push the microphone connector and cable into the bezel through that slot.
Pull the LCD temperature sensor connector straight up out of its socket on the logic board.
If necessary, de-route the LCD temperature sensor cable from behind the logic board.
Remove the two 5.3 mm T6 Torx screws securing the data display cable to the logic board.
Use the attached black tab to pull the data display cable connector away from the logic board.
Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
With the display panel still lifted, disconnect the four inverter cables.
If you are replacing a hard drive and have an extra set of hands, it is possible to reach in and remove the drive without disconnecting anything but the LCD temp and display connector in the previous step with the LCD in its propped position.
Once the LCD panel is removed you need to peel back the black foil from the top edge of the LCD to reveal the clear plastic PCB protector.
There are a total of 8 flex cables along the top edge
Use a T10 Torx driver to remove the 2 screws from each side bracket (total 4 screws)
Stand the LCD panel on its TOP edge and locate the lock tabs along the BOTTOM edge. There are 5 along the length of the bottom edge
Use a flat blade driver or metal spudger to Gently pop the bezel off the lock tabs.
Locate the lock tabs on either side of the LCD panel. There are 2 on each side
Use a flat blade driver or metal spudger to Gently pop the bezel off the side lock tabs.
Now gently separate the metal bezel from the main body of the LCD panel
Lay the LCD panel down on with viewing side UP and remove the metal bezel
Note the 3 flex tabs on the left edge
Once the LCD is loose you need to HOLD it in place in the black plastic frame and GENTLY flip the entire assembly so the LCD is flat on the work surface
Remove the tape securing the LVDS cable
Press IN the 2 silver spring loaded catches on either side to release the cable and gently extract it from the connector
Peel the back Black foil and clear plastic PCB protector to fully expose the PCB that runs across the top of the LCD assembly
Remove the 2ea Philips head screws from each end of the PCB
Gently flip the PCB over 180deg so it is off the aluminum back panel.
Now lift the the back panel off the LCD separating the LCD from the back light assembly
Remove the 6 Philips screws from the rear of the back light assembly
Removing the white tape from the CCFL cable.
Un-clip the CCFL cable from the black plastic surround
Separate the black plastic surround from the aluminum back plate to access the CCFL tube assemblies
Start by un-clipping the tabs along the top edge of the assembly. There are 4 tabs along the top
The top CCFL tube can be seen and CAREFULLY removed
The bottom of the black surround can now be un-clipped and the entire surround removed
There are 4 tabs along the bottom of the assembly
Once the black surround is off the rest pretty much comes apart with the bottom CCFL tube being able to be removed in a similar manner to the top
The centre of the back light assembly is made up of 4 main parts. A perspex sheet with white plastic coating, 2 opaque matt plastic sheets, and 1 Pearlescent matt plastic sheet
The CCLF tube assemblies are made up of a U shaped reflector with 2ea individual tubes inside. The entire assembly is 457mm long and 7.6mm wide. There are no part numbers on the assembly however there is a S on the end with the wires attached and an 18 on the other end.
The individual tubes are 448mm long (excluding the terminals - standard way to measure is end of glass to end of glass) and are 2.4mm diameter.
Remove the white tape from either end of the rear of the CCFL assembly.
Carefully remove about 15-20mm of heat shrink from the CCFL cable to allow the end cap to be removed, making sure you DO NOT cut or nick the wire insulation.
While holding the assembly, slowly and gently pull the THICK wires up and out of the slots in the white rubber cap.
This will reveal the pins and solder joints.
Gently push the THIN wires through the rubber end cap to create a bit of a loop on the rear of the assembly.
Using a plastic pry tool you can pop the rubber end cap out and then lift the thin wires out of the groove in the rear of the CCFL assembly
Run the pry tool the length of the assembly and free the wires all the way to the other end cap
gently pop the rubber end cap out of the assembly
Gently pull the rubber end cap off the CCFL to expose the pins and solder joints
Now its a simple task of un-soldering each wire and soldering in the new CCFL
There is a little figure 8 rubber band tying the 2 CCFL together at their centre.
5 weitere Personen haben diese Anleitung absolviert.
