Zum Hauptinhalt wechseln
Removing Creative Zen Vision W Back Cover
Was du brauchst
  1. Removing Creative Zen Vision W Back Cover, Battery Removal: Schritt 1, Bild 1 von 3 Removing Creative Zen Vision W Back Cover, Battery Removal: Schritt 1, Bild 2 von 3 Removing Creative Zen Vision W Back Cover, Battery Removal: Schritt 1, Bild 3 von 3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Removing Creative Zen Vision W Back Cover, Back Cover: Schritt 2, Bild 1 von 1
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  3. Removing Creative Zen Vision W Back Cover: Schritt 3, Bild 1 von 2 Removing Creative Zen Vision W Back Cover: Schritt 3, Bild 2 von 2
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  4. Removing Creative Zen Vision W Back Cover: Schritt 4, Bild 1 von 3 Removing Creative Zen Vision W Back Cover: Schritt 4, Bild 2 von 3 Removing Creative Zen Vision W Back Cover: Schritt 4, Bild 3 von 3
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
Abschluss
Gabriele Pregadio
1 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-2, Regan Spring 2013 Mitglied von Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 746
