Zum Hauptinhalt wechseln
Removing DVD Drive from Acer Aspire 5100
Was du brauchst
  1. Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: Schritt 1, Bild 1 von 2 Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: Schritt 1, Bild 2 von 2
    • Locate tab with battery symbol on back of laptop. Slide to left to eject battery.
  2. Removing DVD Drive from Acer Aspire 5100: Schritt 2, Bild 1 von 1
    • Locate cover on back of laptop, diagonal to battery compartment. Remove four screws securing cover.
  3. Removing DVD Drive from Acer Aspire 5100: Schritt 3, Bild 1 von 2 Removing DVD Drive from Acer Aspire 5100: Schritt 3, Bild 2 von 2
    • After removing screws, carefully detach cover. You will see the cooling fan in the corner.
  4. Removing DVD Drive from Acer Aspire 5100: Schritt 4, Bild 1 von 2 Removing DVD Drive from Acer Aspire 5100: Schritt 4, Bild 2 von 2
    • Opposite the cooling fan is the component that contains the RAM card. Remove the screws holding the component in place. Carefully detach the component to expose the RAM card.
  5. Removing DVD Drive from Acer Aspire 5100: Schritt 5, Bild 1 von 1
    • Locate the DVD drive and remove screw securing drive. Carefully push drive out from laptop.
Abschluss
To reassemble, follow above steps in reverse.
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 18-66, Johann Spring 2010 Mitglied von Cal Poly, Team 18-66, Johann Spring 2010
CPSU-JOHANN-S10S18G66
5 Mitglieder
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 21
Letzte 30 Tage: 70
Insgesamt: 3,278
