Zum Hauptinhalt wechseln
Delphi MyFi XM2GO Motherboard Replacement
Was du brauchst
  1. Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: Schritt 1, Bild 1 von 3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: Schritt 1, Bild 2 von 3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: Schritt 1, Bild 3 von 3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Delphi MyFi XM2GO Motherboard Replacement, Battery: Schritt 2, Bild 1 von 3 Delphi MyFi XM2GO Motherboard Replacement, Battery: Schritt 2, Bild 2 von 3 Delphi MyFi XM2GO Motherboard Replacement, Battery: Schritt 2, Bild 3 von 3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. Delphi MyFi XM2GO Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 2 Delphi MyFi XM2GO Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
  4. Delphi MyFi XM2GO Motherboard Replacement: Schritt 4, Bild 1 von 3 Delphi MyFi XM2GO Motherboard Replacement: Schritt 4, Bild 2 von 3 Delphi MyFi XM2GO Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
  5. Delphi MyFi XM2GO Motherboard Replacement: Schritt 5, Bild 1 von 3 Delphi MyFi XM2GO Motherboard Replacement: Schritt 5, Bild 2 von 3 Delphi MyFi XM2GO Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the two screws under the button using the T6 Torx screwdriver.
  6. Delphi MyFi XM2GO Motherboard Replacement: Schritt 6, Bild 1 von 2 Delphi MyFi XM2GO Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the back cover.
  7. Delphi MyFi XM2GO Motherboard Replacement: Schritt 7, Bild 1 von 2 Delphi MyFi XM2GO Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the power button by pulling it to the left.
  8. Delphi MyFi XM2GO Motherboard Replacement: Schritt 8, Bild 1 von 2 Delphi MyFi XM2GO Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the plastic antenna extension connector on the right side of the device.
  9. Delphi MyFi XM2GO Motherboard Replacement: Schritt 9, Bild 1 von 3 Delphi MyFi XM2GO Motherboard Replacement: Schritt 9, Bild 2 von 3 Delphi MyFi XM2GO Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Pull up on the motherboard to remove it from the device.
    • The LCD screen and keypad are only connected to the motherboard with ribbon cables. They will hang down as the motherboard is removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Scott Byer
61 Reputation
5 Anleitungen geschrieben
Clemson, Team 1-2, Benson Spring 2012 Mitglied von Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 10
Insgesamt: 2,494
