Was du brauchst
Locate the large button on the top of the device.
Push down on the button and slide the cover away from the button.
Grab the red pull tab and pull down to unlock the latch.
Pull the battery out.
Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
Remove the plastic antenna extension connector on the right side of the device.
The logic board must be exposed to begin.
Flip the device over (see second picture).
Pivot the LCD screen, pulling on the top and sides and keeping the bottom attached.
Continue to pivot the screen until it is lying on its face.
Pivot the wire frame, that was under the LCD, from the left side.
With the frame perpendicular to the device, locate the two black, plastic tabs shown in the two red circles.
The boxes show more detailed views in the following pictures.
WIth both hands, pull the tabs outwards to release the plastic cover from the board.
Once the tabs are disengaged, pivot the plastic cover upwards.
After the cover is pivoted slightly, remove it from the device.
After the plastic cover is removed, locate the white, ribbon connector highlighted by the red square.
Rotate the device 90 degrees counterclockwise to remove the ribbon connector.
To remove the ribbon cable from the board, catch the sides of the connector with fingernails and pull downward.
After the latch is pulled down, the ribbon cable is free to slide out of the connector housing.
After following the prerequisite steps in the guide, the components are laid out as depicted in the picture.
The LCD screen is highlighted in red.
