Einleitung
This guide will show you how to remove the CPU Cooler on your HP Compaq dx2000MT.
  1. Turn off your computer and remove the power cable by pulling it straight out of its socket.
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Remove the 2 Phillips #2 screws that secure the case door to the device. Remove the 2 Phillips #2 screws that secure the case door to the device.
    • Remove the 2 Phillips #2 screws that secure the case door to the device.
  3. Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
    • Once again, this may take considerable force.
  6. Remove the 3 pin power connector by pulling it towards the side of the device. Remove the 3 pin power connector by pulling it towards the side of the device.
    • Remove the 3 pin power connector by pulling it towards the side of the device.
  7. Unscrew the 4 Torx T15 screws holding the CPU Cooler in place. Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  8. Remove the cpu cooler by pulling out towards the side of the device. Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Logan Pace
2.020 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 17-16, Regan Fall 2011 Mitglied von Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Mitglieder
17 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 64
Insgesamt: 4,102
