Zum Hauptinhalt wechseln
Removing HP Compaq dx2000MT PCI Cards
Was du brauchst
  1. Removing HP Compaq dx2000MT PCI Cards, Removing the HP Compaq dx2000MT Case Doors: Schritt 1, Bild 1 von 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT PCI Cards: Schritt 2, Bild 1 von 2 Removing HP Compaq dx2000MT PCI Cards: Schritt 2, Bild 2 von 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT PCI Cards: Schritt 3, Bild 1 von 3 Removing HP Compaq dx2000MT PCI Cards: Schritt 3, Bild 2 von 3 Removing HP Compaq dx2000MT PCI Cards: Schritt 3, Bild 3 von 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT PCI Cards: Schritt 4, Bild 1 von 3 Removing HP Compaq dx2000MT PCI Cards: Schritt 4, Bild 2 von 3 Removing HP Compaq dx2000MT PCI Cards: Schritt 4, Bild 3 von 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT PCI Cards, PCI Cards: Schritt 5, Bild 1 von 2 Removing HP Compaq dx2000MT PCI Cards, PCI Cards: Schritt 5, Bild 2 von 2
    • Remove the Torx T15 screwdriver holding the PCI card in place.
  6. Removing HP Compaq dx2000MT PCI Cards: Schritt 6, Bild 1 von 1
    • Remove the PCI card by pulling it out towards the side of the device.
    • Be careful about touching the top and bottom of the card! The static electricity in your fingers could short it. If you can, only touch the metal bracket and the sides of the card.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Logan Pace
2.305 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 17-16, Regan Fall 2011 Mitglied von Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 22
Insgesamt: 5,271
