Einleitung
This guide will show you how to remove the power supply on your HP Compaq dx2000MT.
Was du brauchst
Turn off your computer and remove the power cable by pulling it straight out of its socket.
Remove the side case door by pushing towards the rear of the device with your hand.
Once you slide the door back, remove it by pulling it outwards from the device.
Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
Slide the power supply towards the front of the device
Then pull the power supply down and remove it from the case.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
