Einleitung
This guide will show you how to remove the laptop RAM.
Was du brauchst
Place the laptop on a fat surface with the underside facing up
Remove the 4 Philips head screws.
Turn the computer over and open the display
Grasping each side of the palm rest, gently lift it off and rotate toward the front of the laptop
Locate the RAM modules
Gently press the metal tabs outwards to release the top RAM module and remove it from the laptop
With the top RAM module removed you can release the lower RAM module in the same manner.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
