Einleitung
Only requires removing a few screws. No special tools required.
Was du brauchst
Flip the camera so that the bottom is facing you.
Take a spare coin and unscrew the battery cover off.
Remove two 4.8mm screws.
Remove one 3.4mm screw.
Remove one 2.65mm screw.
Lift off the back cover.
Remove three 3.5mm screws.
Remove two 3.8mm screws.
Remove one 6.35mm screw.
Remove one 4mm screw. Lift off the disk.
Remove one 5.11mm screw.
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
good advice, will use, have multiple Minolta cameras to work with.
