Zum Hauptinhalt wechseln
Removing Minolta X-370 Lens Holder
Was du brauchst
  1. Removing Minolta X-370 Lens Holder, Battery: Schritt 1, Bild 1 von 2 Removing Minolta X-370 Lens Holder, Battery: Schritt 1, Bild 2 von 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: Schritt 2, Bild 1 von 1
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: Schritt 3, Bild 1 von 2 Removing Minolta X-370 Lens Holder, Bottom Cover: Schritt 3, Bild 2 von 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: Schritt 4, Bild 1 von 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: Schritt 5, Bild 1 von 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: Schritt 6, Bild 1 von 3 Removing Minolta X-370 Lens Holder, Lens Holder: Schritt 6, Bild 2 von 3 Removing Minolta X-370 Lens Holder, Lens Holder: Schritt 6, Bild 3 von 3
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
  7. Removing Minolta X-370 Lens Holder: Schritt 7, Bild 1 von 3 Removing Minolta X-370 Lens Holder: Schritt 7, Bild 2 von 3 Removing Minolta X-370 Lens Holder: Schritt 7, Bild 3 von 3
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: Schritt 8, Bild 1 von 2 Removing Minolta X-370 Lens Holder: Schritt 8, Bild 2 von 2
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: Schritt 9, Bild 1 von 3 Removing Minolta X-370 Lens Holder: Schritt 9, Bild 2 von 3 Removing Minolta X-370 Lens Holder: Schritt 9, Bild 3 von 3
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: Schritt 10, Bild 1 von 2 Removing Minolta X-370 Lens Holder: Schritt 10, Bild 2 von 2
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: Schritt 11, Bild 1 von 2 Removing Minolta X-370 Lens Holder: Schritt 11, Bild 2 von 2
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: Schritt 12, Bild 1 von 3 Removing Minolta X-370 Lens Holder: Schritt 12, Bild 2 von 3 Removing Minolta X-370 Lens Holder: Schritt 12, Bild 3 von 3
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Nick
525 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 8-7, Regan Spring 2011 Mitglied von Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Mitglieder
9 Anleitungen geschrieben
1 Kommentar zur Anleitung
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 44
Insgesamt: 7,796
