Einleitung
Step-by-step guide to removing your phone's back plate.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Flip phone to see back cover. Using either finger or spugder tool press button located  near the top of phone by the antenna.
    • Flip phone to see back cover.
    • Using either finger or spugder tool press button located near the top of phone by the antenna.
  2. Pry up back plate from phone to reveal battery. Push button near bottom of battery using either your finger of the spudger.  This will release the battery.
    • Pry up back plate from phone to reveal battery.
    • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
    • Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
  5. Simultaneously press indicated buttons on both sides of phone. Simultaneously press indicated buttons on both sides of phone.
    • Simultaneously press indicated buttons on both sides of phone.
  6. Separate back plate from the rest of phone.
    • Separate back plate from the rest of phone.
    • Make sure to not pull, there is a wire (circled on image) connecting the two plates.
Abschluss
Elizabeth OBrien
31 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 30-40, Garner Spring 2010 Mitglied von Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Mitglieder
14 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 3,186
