Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide has been updated by iFixit staff! Read the new, official guide here.
This guide will show you how to remove the screws that hold the Logic Board into place. From here, some repairs may be done that require you disconnect all connected modules, and some may not require that you disturb the connections.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place your device upside down and locate the battery compartment.
    • Place your device upside down and locate the battery compartment.
    • Find the phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a phillips screwdriver to remove screw.
  2. Slowly remove the battery cover with the iFixit opening tool.
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing phillips screw in the cover. It will be needed for reassembly.
  3. Use the iFixit opening tool to carefully pry the battery out of the case. After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
  4. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  5. Place the battery cover on the top and gently screw in the phillips head screw to firmly secure the battery.
    • Place the battery cover on the top and gently screw in the phillips head screw to firmly secure the battery.
    • Use only the phillips screwdriver to tighten the screw.
    • After this step you will have successfully relpaced your Nintendo DS battery.
  6. Remove the following 7 screws securing the lower case to the DS Lite:
    • Remove the following 7 screws securing the lower case to the DS Lite:
    • 3 silver tri-wing screws (5mm long)
    • 1 black tri-wing screw (4mm)
    • 2 gold Phillips screws (4mm)
    • 1 silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
  7. Remove the plastic insert (or cartridge) from the lower slot (Slot 2).
    • Remove the plastic insert (or cartridge) from the lower slot (Slot 2).
  8. Flip the unit over. Use a spudger to pry open the gap between the bottom case and the front panel.  Work all the way around the case until the panel is free.
    • Flip the unit over.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they pop off easily and are difficult to reassemble. Keeping the bottom case against your workbench will help hold them in place.
  9. Carefully separate the two pieces by hand. The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring.  If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position. When reassembling the cover, make sure that the power switch cover on the bottom case is in the off (down) position. Otherwise, the power switch cover can break the very fragile power switch upon reassembly.
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power switch cover on the bottom case is in the off (down) position. Otherwise, the power switch cover can break the very fragile power switch upon reassembly.
  10. After taking the bottom case off, remove two Phillips #00 screws that secure the logic board to the plastic case.
    • After taking the bottom case off, remove two Phillips #00 screws that secure the logic board to the plastic case.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
bushing
9.840 Reputation
13 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 18
Letzten 30 Tage: 87
Insgesamt: 6,415
