Zum Hauptinhalt wechseln
Removing Olympus FE-210 Motherboard
Was du brauchst
  1. Removing Olympus FE-210 Motherboard, Battery: Schritt 1, Bild 1 von 2 Removing Olympus FE-210 Motherboard, Battery: Schritt 1, Bild 2 von 2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 Motherboard: Schritt 2, Bild 1 von 2 Removing Olympus FE-210 Motherboard: Schritt 2, Bild 2 von 2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 Motherboard, Front Casing: Schritt 3, Bild 1 von 3 Removing Olympus FE-210 Motherboard, Front Casing: Schritt 3, Bild 2 von 3 Removing Olympus FE-210 Motherboard, Front Casing: Schritt 3, Bild 3 von 3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 Motherboard: Schritt 4, Bild 1 von 3 Removing Olympus FE-210 Motherboard: Schritt 4, Bild 2 von 3 Removing Olympus FE-210 Motherboard: Schritt 4, Bild 3 von 3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Removing Olympus FE-210 Motherboard, Rear Casing: Schritt 5, Bild 1 von 1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Removing Olympus FE-210 Motherboard: Schritt 6, Bild 1 von 3 Removing Olympus FE-210 Motherboard: Schritt 6, Bild 2 von 3 Removing Olympus FE-210 Motherboard: Schritt 6, Bild 3 von 3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  7. Removing Olympus FE-210 Motherboard, LCD Screen: Schritt 7, Bild 1 von 2 Removing Olympus FE-210 Motherboard, LCD Screen: Schritt 7, Bild 2 von 2
    • Remove the two 2.7 mm screws using a #00 screwdriver.
    • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
  8. Removing Olympus FE-210 Motherboard: Schritt 8, Bild 1 von 3 Removing Olympus FE-210 Motherboard: Schritt 8, Bild 2 von 3 Removing Olympus FE-210 Motherboard: Schritt 8, Bild 3 von 3
    • Using a spudger, lift the latch on the connector.
    • Remove the ribbon cord from its connector.
    • Remove the LCD from the rest of the camera.
  9. Removing Olympus FE-210 Motherboard, Motherboard: Schritt 9, Bild 1 von 2 Removing Olympus FE-210 Motherboard, Motherboard: Schritt 9, Bild 2 von 2
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
  10. Removing Olympus FE-210 Motherboard: Schritt 10, Bild 1 von 2 Removing Olympus FE-210 Motherboard: Schritt 10, Bild 2 von 2
    • Remove the seven 2.7 mm using a #00 screwdriver.
  11. Removing Olympus FE-210 Motherboard: Schritt 11, Bild 1 von 1
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
  12. Removing Olympus FE-210 Motherboard: Schritt 12, Bild 1 von 1
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
  13. Removing Olympus FE-210 Motherboard: Schritt 13, Bild 1 von 2 Removing Olympus FE-210 Motherboard: Schritt 13, Bild 2 von 2
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
  14. Removing Olympus FE-210 Motherboard: Schritt 14, Bild 1 von 1
    • Remove the motherboard from the camera casing.
Abschluss
Alex Wolff
234 Reputation
1 Anleitung geschrieben
Cal Poly, Team 4-36, Regan Winter 2011 Mitglied von Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 3,849
