Zum Hauptinhalt wechseln
Removing Samsung DVD-P230 Tray
Was du brauchst
  1. Removing Samsung DVD-P230 Tray, Outer Cover & Faceplate: Schritt 1, Bild 1 von 3 Removing Samsung DVD-P230 Tray, Outer Cover & Faceplate: Schritt 1, Bild 2 von 3 Removing Samsung DVD-P230 Tray, Outer Cover & Faceplate: Schritt 1, Bild 3 von 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Removing Samsung DVD-P230 Tray: Schritt 2, Bild 1 von 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Removing Samsung DVD-P230 Tray: Schritt 3, Bild 1 von 1
    • Unscrew the 3 screws in the back.
  4. Removing Samsung DVD-P230 Tray: Schritt 4, Bild 1 von 2 Removing Samsung DVD-P230 Tray: Schritt 4, Bild 2 von 2
    • Pull the outer case upward and then towards you.
  5. Removing Samsung DVD-P230 Tray: Schritt 5, Bild 1 von 3 Removing Samsung DVD-P230 Tray: Schritt 5, Bild 2 von 3 Removing Samsung DVD-P230 Tray: Schritt 5, Bild 3 von 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Removing Samsung DVD-P230 Tray: Schritt 6, Bild 1 von 2 Removing Samsung DVD-P230 Tray: Schritt 6, Bild 2 von 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Removing Samsung DVD-P230 Tray, Power Cord: Schritt 7, Bild 1 von 3 Removing Samsung DVD-P230 Tray, Power Cord: Schritt 7, Bild 2 von 3 Removing Samsung DVD-P230 Tray, Power Cord: Schritt 7, Bild 3 von 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Removing Samsung DVD-P230 Tray, Tray: Schritt 8, Bild 1 von 3 Removing Samsung DVD-P230 Tray, Tray: Schritt 8, Bild 2 von 3 Removing Samsung DVD-P230 Tray, Tray: Schritt 8, Bild 3 von 3
    • Remove the three screws holding in the DVD tray
  9. Removing Samsung DVD-P230 Tray: Schritt 9, Bild 1 von 2 Removing Samsung DVD-P230 Tray: Schritt 9, Bild 2 von 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Removing Samsung DVD-P230 Tray: Schritt 10, Bild 1 von 2 Removing Samsung DVD-P230 Tray: Schritt 10, Bild 2 von 2
    • Gently lift the DVD tray off of the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Evan Domingue
410 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-30, Regan Winter 2011 Mitglied von Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,909
