Einleitung
This guide will explain how to remove the display hinge. The tools required for this section are the spudger and the PH 2 screwdriver.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Before starting, make sure the display is UNPLUGGED.  Failure to do so can result in shock and serious injury.
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
    • Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
    • Once the two screws have been removed, move the cord out of the way.
    • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
    • Then lift out the hinge mount.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Thomas Harper
Mitglied seit 01.04.2011
227 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-41, Forte Spring 2011 Mitglied von Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 6,120
