Einleitung
This guide will help you safely access the inside of your Lenovo A8 without fear of damaging any of the components or the exterior.
Was du brauchst
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
