Zum Hauptinhalt wechseln
Removing the Back Panel
Was du brauchst
  1. Removing the Back Panel, Removing the Back Panel: Schritt 1, Bild 1 von 3 Removing the Back Panel, Removing the Back Panel: Schritt 1, Bild 2 von 3 Removing the Back Panel, Removing the Back Panel: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Removing the Back Panel: Schritt 2, Bild 1 von 3 Removing the Back Panel: Schritt 2, Bild 2 von 3 Removing the Back Panel: Schritt 2, Bild 3 von 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 2,506
