Zum Hauptinhalt wechseln
Removing the Dell Inspiron 1150 Modem Card
Was du brauchst
  1. Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 1 von 3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 2 von 3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 3 von 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Modem Card, Modem Card: Schritt 2, Bild 1 von 3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: Schritt 2, Bild 2 von 3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: Schritt 2, Bild 3 von 3
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. Removing the Dell Inspiron 1150 Modem Card: Schritt 3, Bild 1 von 2 Removing the Dell Inspiron 1150 Modem Card: Schritt 3, Bild 2 von 2
    • Locate the Modem card.
    • Remove the screws.
  4. Removing the Dell Inspiron 1150 Modem Card: Schritt 4, Bild 1 von 2 Removing the Dell Inspiron 1150 Modem Card: Schritt 4, Bild 2 von 2
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
Ziellinie
Lauren
4 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 16-2, Maness Spring 2010 Mitglied von Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 4,529
