Zum Hauptinhalt wechseln
Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual)
Was du brauchst
  1. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 1 von 3 Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 2 von 3 Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: Schritt 1, Bild 3 von 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): Schritt 2, Bild 1 von 3 Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): Schritt 2, Bild 2 von 3 Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): Schritt 2, Bild 3 von 3
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Abschluss
Richdave
32.105 Reputation
30 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.541 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 520
