Zum Hauptinhalt wechseln
Removing the HP Compaq dx2000MT Optical (CD) Drive
Was du brauchst
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: Schritt 1, Bild 1 von 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 2, Bild 1 von 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 2, Bild 2 von 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 3, Bild 1 von 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 3, Bild 2 von 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 3, Bild 3 von 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 4, Bild 1 von 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 4, Bild 2 von 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 4, Bild 3 von 3
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: Schritt 5, Bild 1 von 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: Schritt 5, Bild 2 von 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: Schritt 5, Bild 3 von 3
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 6, Bild 1 von 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 6, Bild 2 von 2
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 7, Bild 1 von 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 7, Bild 2 von 2
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 8, Bild 1 von 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 8, Bild 2 von 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: Schritt 8, Bild 3 von 3
    • Remove the optical drive by sliding it out the front of the device.
Abschluss
Logan Pace
2.251 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 17-16, Regan Fall 2011 Mitglied von Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 1,484
