Einleitung
This guide will show you how to remove the keyboard
Was du brauchst
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
Slide the retention clips toward the keyboard to release the keyboard
Use a plastic pry tool to lift the rear edge of the keyboard.
Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
Lift the keyboard up to reveal the ribbon connectors
Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
Release the smaller ribbon cable by lifting up the white retainer
9 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Look easy to remove !! I have a hp elitebook 6930p it need a new keyboard but it hard for me to find one for my elitebook 6930p online they look the same but none of them have the part number i need ! Could i use any hp elitebook 6930p replacement keyboard or were can i find the right keyboard number on the elitebook 6930 i just might be looking at the wrote number ! Need help !!
CHICONY
MP-06803U46930 MP-06803US6442
DARFON
9J.N8282.K01 NSK-H4K01
HP COMPAQ
483010-001 90.4V907.S01 9J.N8282.K01 BAHHH3AM2WS0E7
MP-06803U46930 MP-06803US6442 NSK-H4K01 V070530CS1
any of these should work
Keegan -
