Einleitung
This guide will show you how to locate and remove the WLAN (WiFi) module.
Was du brauchst
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
Slide the retention clips toward the keyboard to release the keyboard
Use a plastic pry tool to lift the rear edge of the keyboard.
Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
Lift the keyboard up to reveal the ribbon connectors
Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
Release the smaller ribbon cable by lifting up the white retainer
Locate the WLAN module
Use a plastic spugder or similar to carefully remove the 3 antenna wires from the WLAN module.
Remove the 2 M2.5×4.0 screws that secure the WLAN module into the laptop
With the screws removed the right hand end of the WLAN module will pop up. You may now simply remove the module from the edge connector.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
