Zum Hauptinhalt wechseln
Einleitung
This repair is very straightforward and requires no tools to perform.
  1. Press down the button on the back panel.
    • Press down the button on the back panel.
  2. Push the back cover upwards. Push the back cover upwards.
    • Push the back cover upwards.
  3. Remove the back cover from the phone. Remove the back cover from the phone.
    • Remove the back cover from the phone.
  4. Press the silver button on the top of the phone.
    • Press the silver button on the top of the phone.
  5. Slide your thumbnail down the case seam to separate the rest of the case.
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. Gently, remove the case.
    • Gently, remove the case.
    • Careful! Do not bend the plastic tabs.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Spencer Lines
141 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-27, Regan Fall 2010 Mitglied von Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 3,203
