Zum Hauptinhalt wechseln
Removing the Phone Keypad
Was du brauchst
  1. Removing the Phone Keypad, Removing the Back Panel: Schritt 1, Bild 1 von 2 Removing the Phone Keypad, Removing the Back Panel: Schritt 1, Bild 2 von 2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Removing the Phone Keypad: Schritt 2, Bild 1 von 3 Removing the Phone Keypad: Schritt 2, Bild 2 von 3 Removing the Phone Keypad: Schritt 2, Bild 3 von 3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Removing the Phone Keypad, Keypad: Schritt 3, Bild 1 von 2 Removing the Phone Keypad, Keypad: Schritt 3, Bild 2 von 2
    • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
  4. Removing the Phone Keypad: Schritt 4, Bild 1 von 1
    • Lift the motherboard away from the phone housing.
    • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
  5. Removing the Phone Keypad: Schritt 5, Bild 1 von 2 Removing the Phone Keypad: Schritt 5, Bild 2 von 2
    • Now that the motherboard has been lifted out of place, the keypad can be accessed.
    • Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Remove the keypad from the assembly.
Abschluss
Clemson, Team 15-1, Benson Fall 2012 Mitglied von Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 947
