Einleitung
If your Kurio Xtreme's speakers are not working properly, follow these steps to replace the faulty speakers with new speakers. Before proceeding, make sure that you have a soldering iron and know how to use it.
Was du brauchst
Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
Carefully lift the back panel off of the rest of the device.
Disconnect the 2 sets of black and red wires (4 wires total) from the motherboard by soldering the ends connected to the motherboard.
Carefully remove the speakers out of the plastic molds by lifting up the black and red wires.
