Zum Hauptinhalt wechseln
Repair Daewoo soup maker SDA1714
Was du brauchst
  1. Repair Daewoo soup maker SDA1714, General view of soup maker: Schritt 1, Bild 1 von 1
    • General view of Daewoo soup maker 1000w 1.6l model SDA1714 date code 09/2020
  2. Repair Daewoo soup maker SDA1714, Turn lid up-side-down: Schritt 2, Bild 1 von 1
    • With the mains disconnected, remove the lid and invert it and place on jug as shown. (This keeps the lid upright and steady)
    • Note that there are 4 pins on the lid section and 4 holes in the jug section (yellow arrows)
    • Spray some electrical contact cleaner on the 4 pins and replace the lid section the right way up on the jug about 20 times, so that that the electrical contacts rub against each other numerous times to remove any non-conducting residue.
    • Wipe away any liquid and allow to dry (for an hour or so?)
    • Hopefully the soup maker will now come on when plugged into the mains. The buzzer should sound and the LED lights should flash awaiting the mode button to be pressed.
    • If the soup maker does not turn on, disconnect from mains and repeat the cleaning process with the contact cleaner.
  3. Repair Daewoo soup maker SDA1714: Schritt 3, Bild 1 von 1
    • If cleaning the contacts several times in the previous step did not work, remove the 13 screws to split the lid in two as shown in the image and replace the lid (the right way up with mains turn off!)
    • With a multimeter, measure the resistance between the two terminals marked with green arrows. It should be about 60ohms.
    • If the resistance is much higher or open circuit, then either the contacts need more cleaning, or the thermal fuse/ heating element has failed (not covered by this simple guide)
    • Note: if the thermal fuse or element has failed, the soup maker will not work at all even in the blender mode which does not require the heater.
Abschluss
This is a quick technique to get a soup maker working again with no special diy skills . All carried out safely with the mains power disconnected. If this doesn't work, then some diy/ disassembly skills are required eg changing a thermal fuse (not covered here).
Eine weitere Person hat diese Anleitung absolviert.
Dave Empson
3.169 Reputation
31 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 44
Insgesamt: 229
