Einleitung
Mechanical keyboards are conventionally expensive to buy. Having functional keys are essential for a mechanical keyboard.
With the help of this guide, fix unresponsive keys on your mechanical keyboard.
Was du brauchst
Unplug the USB cable to prevent issues during the repair.
Remove all 13 Phillips screws located on the underside of the keyboard and gently remove the casing.
Remove the three screws on the metal bracket located towards the top left on the keyboard.
Remove the rubber underneath the metal bar.
Use a cotton swab and add isopropyl alcohol to thoroughly clean the green membrane sheet and place the green membrane back onto the key switches.
Use electrical tape to fix each contact strip that connects the green membrane to the motherboard into place.
Align the contact strips in place with the black lined traces provided on the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
