Einleitung
You will learn how to repair a slipping scroll wheel on your LG Magic Remote easily.
Was du brauchst
Get your syringe and suck a small amount of glue out of the tube.
Insert the needle of the syringe into the rubber of the remote's scroll wheel until you hit the hard part of the scroll wheel.
Insert a small amount of glue underneath the surface of the rubber. Repeat this at the two other parts of the scroll wheel. Let it dry for 10 minutes. The problem should be solved!
Follow these instructions in reverse order to put your device back together.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Hier starten ›
