Zum Hauptinhalt wechseln
Repairing 1999-2004 Honda Odyssey Rear window actuator
Was du brauchst
    • Download attached PDF.
Abschluss
16 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
Marvin
491 Reputation
1 Anleitung geschrieben
19 Kommentare
Down load didn't work...I would really like to have the answer to this question. PDF does not provide any information...if there are links inside the PDF they don't work either. The key question is how do you remove the panel that covers the Honda Odyssey Rear window actuator?....on a 2002 to be specific?
KHM - Antwort
Worked great!! I only broke 1 clip getting the panels off. That meant I paid the dealer about $1.50 instead of the $300 they wanted to fix it.
Grunt - Antwort
This mod is done to new/working actuators, correct? Not ones that have already failed.
gradh - Antwort
The mod can be done to failed or non-failed actuators. The part that fails is bypassed. It was primarily developed to repair failed actuators.
Marvin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 51
Insgesamt: 60,236
