Zum Hauptinhalt wechseln
Repairing A Torn Skirt Ruffle
Was du brauchst
  1. Repairing A Torn Skirt Ruffle, Repairing A Torn Skirt Ruffle: Schritt 1, Bild 1 von 1
    • Fold the skirt so the ripped part is facing inside and is not visible from the outside.
  2. Repairing A Torn Skirt Ruffle: Schritt 2, Bild 1 von 3 Repairing A Torn Skirt Ruffle: Schritt 2, Bild 2 von 3 Repairing A Torn Skirt Ruffle: Schritt 2, Bild 3 von 3
    • Pin the folded fabric in place, using sewing pins to secure the fabric.
    • Be careful not to pin any extra fabric from the rest of the skirt.
  3. Repairing A Torn Skirt Ruffle: Schritt 3, Bild 1 von 1
    • Match a thread to the fabric.
  4. Repairing A Torn Skirt Ruffle: Schritt 4, Bild 1 von 1
    • Thread your sewing needle, holding your needle straight up and pushing the thread through.
  5. Repairing A Torn Skirt Ruffle: Schritt 5, Bild 1 von 3 Repairing A Torn Skirt Ruffle: Schritt 5, Bild 2 von 3 Repairing A Torn Skirt Ruffle: Schritt 5, Bild 3 von 3
    • Cut the thread to the desired length.
    • It is better to have thread that is too long rather than too short.
    • Tie a knot at the end of the cut thread to secure your stitches.
  6. Repairing A Torn Skirt Ruffle: Schritt 6, Bild 1 von 3 Repairing A Torn Skirt Ruffle: Schritt 6, Bild 2 von 3 Repairing A Torn Skirt Ruffle: Schritt 6, Bild 3 von 3
    • Push your needle in one side of fabric and draw it out on other side to make the first stitch.
  7. Repairing A Torn Skirt Ruffle: Schritt 7, Bild 1 von 2 Repairing A Torn Skirt Ruffle: Schritt 7, Bild 2 von 2
    • Continue sewing in a straight line as demonstrated in Step 7.
    • Remove sewing pins as you go.
  8. Repairing A Torn Skirt Ruffle: Schritt 8, Bild 1 von 2 Repairing A Torn Skirt Ruffle: Schritt 8, Bild 2 von 2
    • When you reach the end of your thread, tie your thread in a knot in order to secure the stitches.
    • Tie your knot as close to the fabric as possible to keep the stitches tight.
  9. Repairing A Torn Skirt Ruffle: Schritt 9, Bild 1 von 2 Repairing A Torn Skirt Ruffle: Schritt 9, Bild 2 von 2
    • Cut off the excess thread.
    • Enjoy your fixed skirt!
Abschluss
Mariam Khan
169 Reputation
1 Anleitung geschrieben
CSU Sacramento, Team 1-13, Laflen Fall 2024 Mitglied von CSU Sacramento, Team 1-13, Laflen Fall 2024
CSUSAC-LAFLEN-F24S1G13
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 152
