Zum Hauptinhalt wechseln
Repairing Acer Aspire 5100 Display Screen
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Repairing Acer Aspire 5100 Display Screen, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
  2. Repairing Acer Aspire 5100 Display Screen, Display Screen: Schritt 2, Bild 1 von 1
    • Flip the laptop back over and open it.
  3. Repairing Acer Aspire 5100 Display Screen: Schritt 3, Bild 1 von 1
    • Pry out the 4 screw covers with a dental pick or other small pointed tool, and remove the screws located beneath them.
  4. Repairing Acer Aspire 5100 Display Screen: Schritt 4, Bild 1 von 2 Repairing Acer Aspire 5100 Display Screen: Schritt 4, Bild 2 von 2
    • Use a plastic spudger to carefully pry the front bezel off.
    • The bezel will tend to "snap" off little by little, as you work around it, don't be afraid to use a little force.
  5. Repairing Acer Aspire 5100 Display Screen: Schritt 5, Bild 1 von 1
    • Now remove the top cover by unscrewing the two Phillips #0 screws found at the bottom of the panel.
    • You are removing the cover behind the LCD, not the LCD screen. The two screws are the only thing holding it so carefully support it so it does not pull on and damage any cables.
  6. Repairing Acer Aspire 5100 Display Screen: Schritt 6, Bild 1 von 1
    • Unplug the display data cable attached to the back of the LCD.
    • Do not touch this area,it destroys the backlight!
  7. Repairing Acer Aspire 5100 Display Screen: Schritt 7, Bild 1 von 1
    • Finally, remove the LCD screen by unscrewing the six screws connecting the LCD panel to the side frame.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
iDeleted
2.101 Reputation
39 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 4,160
