Was du brauchst
Flip device upside down and remove the 4 foam pads at each corner.
Unscrew Circuit board attached to the top of the case with the one screw in the center. Be careful not to strip the screw/break the circuit board.
If everything works on the inside, that might mean you need a new circuit board.
Eine weitere Person hat diese Anleitung absolviert.
