Zum Hauptinhalt wechseln
Repairing Alarm Clock Clock Projector
Was du brauchst
    1. Repairing Alarm Clock Clock Projector, The issue: Schritt 1, Bild 1 von 1
      • The Problem: here I should read 12:47
      Frag FixBot
      Kommentar hinzufügen
    2. Repairing Alarm Clock Clock Projector: Schritt 2, Bild 1 von 2 Repairing Alarm Clock Clock Projector: Schritt 2, Bild 2 von 2
      • After removing the 2 screws on the bottom, carefully open the bottom frame, see location of the plastic snaps snaps
      Frag FixBot
    3. Repairing Alarm Clock Clock Projector: Schritt 3, Bild 1 von 3 Repairing Alarm Clock Clock Projector: Schritt 3, Bild 2 von 3 Repairing Alarm Clock Clock Projector: Schritt 3, Bild 3 von 3
      • Removes the back panel, taking care of the other plastic snaps
      • The projector and its optics is shown in the blue square
      Frag FixBot
    4. Repairing Alarm Clock Clock Projector, The optics: Schritt 4, Bild 1 von 3 Repairing Alarm Clock Clock Projector, The optics: Schritt 4, Bild 2 von 3 Repairing Alarm Clock Clock Projector, The optics: Schritt 4, Bild 3 von 3
      • cables are tied together with a simple ribbon, in general the inner construction seems very cheap
      • The Projector is made of three parts:
      • A red LED
      • The display with its controller
      • the lens with focus mechanics
      • All parts are kept by tiny screws that you have to remove
      • Take extra caution when handling the display, the flat cable is very weak and can be damaged by improper handling
      Frag FixBot
    5. Repairing Alarm Clock Clock Projector: Schritt 5, Bild 1 von 3 Repairing Alarm Clock Clock Projector: Schritt 5, Bild 2 von 3 Repairing Alarm Clock Clock Projector: Schritt 5, Bild 3 von 3
      • Carefully remove display from its supporting frame
      • The issue should be ralated to flat cable connecting display to controller
      Frag FixBot
    6. Repairing Alarm Clock Clock Projector: Schritt 6, Bild 1 von 3 Repairing Alarm Clock Clock Projector: Schritt 6, Bild 2 von 3 Repairing Alarm Clock Clock Projector: Schritt 6, Bild 3 von 3
      • Verify that moving the flat the display returns to work
      • put a stiffner on controller side and close to the display
      • if everything is working, reassemble the clock by doing the steps in reverse order
      Frag FixBot
    7. Repairing Alarm Clock Clock Projector: Schritt 7, Bild 1 von 1
      • Problem solved.
      Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
6 Kommentare zur Anleitung
The clock projection displays only partial numbers.one number is missing. The face on the clock displays perfect. It's just The projection on the wall that's missing a digit
eacoch - Antwort Teilen
my Peakeep clock keeps the correct time but you can't see the time clearly. It's as if the light is turned off.
serena williams - Antwort Teilen
Thank you for this post! It was the exact starting point to fix my projection clock which was looking dull and had lost a few segments. While the addition of supporting tape helped for a short period, doing it again in conjunction with Step 6 of the following link (http://www.instructables.com/id/How-to-r...) - Applying heat - to the ribbon contact points was the ticket that restored my projection clock functionality.
Adam - Antwort Teilen
Hi Adam, glad to helped you
Andrea Gangemi - Antwort Teilen
The display on my clock is missing parts of a number but project correct time , help ?
mandzb87 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 34
Letzte 30 Tage: 108
Insgesamt: 15,210
