1. Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
    • Remove the following screws that secure the top and bottom halves of the base.
      • One 1/4 Phillips screw
      • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
    • Tug on wires in the marked locations to make sure they are secure.
    • If the wire stays still, the connection is secure.
      • If you still have problems with the blender, it is probably a problem with the motor. Since the motor is irreplaceable, you will have to order a new blender.
    • If the wire comes off, the connection is insecure. You will need to solder the connection to make it solid again.
    • If you don't know how to solder, here is a link to show you how. http://www.aaroncake.net/electronics/sol...
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Elmer Pres Urbano
Mitglied seit 05.10.2012
142 Reputation
1 Anleitung geschrieben
Cal Poly, Team 6-34, Regan Fall 2012 Mitglied von Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 2,434
