Was du brauchst
Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
Remove the following screws that secure the top and bottom halves of the base.
One 1/4 Phillips screw
One TA-20 screw
Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
Tug on wires in the marked locations to make sure they are secure.
If the wire stays still, the connection is secure.
If you still have problems with the blender, it is probably a problem with the motor. Since the motor is irreplaceable, you will have to order a new blender.
If the wire comes off, the connection is insecure. You will need to solder the connection to make it solid again.
If you don't know how to solder, here is a link to show you how. http://www.aaroncake.net/electronics/sol...
4 weitere Nutzer:innen haben diese Anleitung absolviert.
