Zum Hauptinhalt wechseln
Repairing Buttons on Casio fx-300ES Calculator
Was du brauchst
  1. Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: Schritt 1, Bild 1 von 2 Repairing Buttons on Casio fx-300ES Calculator, Repairing Buttons on Casio fx-300ES Calculator: Schritt 1, Bild 2 von 2
    • Remove the six 5 mm screws on the back of the calculator.
  2. Repairing Buttons on Casio fx-300ES Calculator: Schritt 2, Bild 1 von 2 Repairing Buttons on Casio fx-300ES Calculator: Schritt 2, Bild 2 von 2
    • Carefully remove the back plate to reveal the circuit board and the battery.
  3. Repairing Buttons on Casio fx-300ES Calculator: Schritt 3, Bild 1 von 3 Repairing Buttons on Casio fx-300ES Calculator: Schritt 3, Bild 2 von 3 Repairing Buttons on Casio fx-300ES Calculator: Schritt 3, Bild 3 von 3
    • Remove the four 4 mm screws from the circuit board.
  4. Repairing Buttons on Casio fx-300ES Calculator: Schritt 4, Bild 1 von 1
    • Be aware of the placement of the blue, black, red, and yellow wires because they will fall out when the next step is taken.
  5. Repairing Buttons on Casio fx-300ES Calculator: Schritt 5, Bild 1 von 3 Repairing Buttons on Casio fx-300ES Calculator: Schritt 5, Bild 2 von 3 Repairing Buttons on Casio fx-300ES Calculator: Schritt 5, Bild 3 von 3
    • Carefully lift the circuit board while leaving the grey rubber piece face down.
    • Simply flip the circuit board and the screen over but do not remove them fully.
    • Make sure the calculator is face down.
    • Buttons are loose do not flip calculator over.
  6. Repairing Buttons on Casio fx-300ES Calculator: Schritt 6, Bild 1 von 3 Repairing Buttons on Casio fx-300ES Calculator: Schritt 6, Bild 2 von 3 Repairing Buttons on Casio fx-300ES Calculator: Schritt 6, Bild 3 von 3
    • Now lift the grey rubber piece off to reveal the individual buttons.
    • Buttons are loose make sure they do not come off with the rubber piece.
  7. Repairing Buttons on Casio fx-300ES Calculator: Schritt 7, Bild 1 von 3 Repairing Buttons on Casio fx-300ES Calculator: Schritt 7, Bild 2 von 3 Repairing Buttons on Casio fx-300ES Calculator: Schritt 7, Bild 3 von 3
    • To remove the buttons you can use your screwdriver and lightly flip them out of their individual spaces.
    • You can now access all the buttons and make any alterations needed.
  8. Repairing Buttons on Casio fx-300ES Calculator: Schritt 8, Bild 1 von 1
    • Refer to this picture if any buttons get misplaced or fall out.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 28-2, Green Spring 2015 Mitglied von Cal Poly, Team 28-2, Green Spring 2015
CPSU-GREEN-S15S28G2
4 Mitglieder
2 Anleitungen geschrieben
4 Kommentare
Great photos make sure to replace the stock photos with those you take. Maybe retake photos with white background.
Kathryn Webb - Antwort
my answer key button not working. when i press button it shows the X10 so what can i do plzz give tips for repairing
ayush shukla - Antwort
Halp my board is stuck to the front plate sith super glue from previous owner.
[deleted] - Antwort
I repaired my Casio fx-300w, a similar calculator with similar buttons. My mother, who gave it to me, spilled coffee once when using it in her office. I got rid of the sticky coffee gunk formed nearly 12 years ago.
Matthew Yang - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 26
Letzte 30 Tage: 98
Insgesamt: 24,849
