Einleitung
A simple, but effective and lasting DIY repair.
You'll need
-a small phillips screwdriver
-a thick guitar string. (I used a light gauge G) THIS WILL NOT WORK WITH PLAIN WIRE! Don't use anything bigger than a .8mm and no smaller than a .6mm string.
Was du brauchst
Cut a thick guitar string to about 1" in length
Create a very slight "U" curve 1/2" long, leaving 1/4" of straight wire on each side of the curve.
Be sure that the straight ends of the wire are in line with each other.
Remove the battery door by opening, then pulling it from the slots on the camera.
Remove the screws on the battery door.
Then remove the release switch from the door
