Einleitung
Remove two screws, gently pry away cover and readjust your slider button. Easy!
Was du brauchst
Remove screws on strap panel of camera.
After removing the two screws on your strap plate, gently pry away the back cover of your camera.
Now readjust the slider button so that it is in the correct position. (You will know this works, if the button will freely move once the cover is on)
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
