Einleitung
If you have a cup holder but it wont open then this guide will take you through the steps you need to do to fix this problem.
Was du brauchst
Apply putty knife to edge of cover until it pops open
Remove screws off of broken cup holder
Take cup holder out
Remove plastic cover on cup holder by pulling apart where the lips meet
Locate spring in device
Fully take apart the cup holder to get to the inside of the cup holder
Locate where spring is placed
Locate where the spring connects
If hole is not broken then just apply spring into hole
If the hole broke, like in this case here, then drill a hole the size of the spring around the same spot of the other hole
Follow these steps step by step to get your broken cup holder fixed.
18 weitere Personen haben diese Anleitung absolviert.
6 Kommentare
Easy fix that saved over $60 if I had to purchase a new part and much much more if the the dealer were to have fixed this. Thank you
clever idea when plastic holding the spring hook is broken. nice hack of a fix.
Is there any way to purchase just the spring? In my case the plastic is fine, it’s the shaped metal tip of the spring that sheared off somehow!? I also need the tentioner.
This happened to me as well. I broke off the end of the coil/spring while bending to make a “hook” shape.
I looked for purchasing just the spring, but could not find it. Next up was the entire cupholder apparatus, either used ($~26), URO ($~39), or OEM/genuine BMW ($60-75+). This isn’t cheap and is not actually necessary to buy anything ,though.
Much easier is what I did instead, which was taking advantage of the coil material’s rigid/”easily-snap-off-able” property to make a new (wider) hook. I pulled the snapped end of the coil out a little, then put in a thin screwdriver to kind of hold the coil out extended. Next I used flat nose pliers to hold the end flat, while using long nose pliers to break off a new gap on both sides, effectively making a new “t” end. Then of course I VERY GENTLY bent it around to make a “hook”. I gently clipped the new spring hook into the preexisting plastic hole. It works for new after reinstalling. We’ll see how it holds up!
Dealer wanted $180. Flat spring has T on end and locks into corresponding T in plastic. My plastic was broken out on one side. I merely took a bit in my dremel, and made the old T deeper in order to catch the metal end.
