Zum Hauptinhalt wechseln
Repairing DSC-RX100 Error: "Turn camera off then on" / "Kamera aus- und wieder einschalten"
Was du brauchst
    • Turn off the power.
    • Remove the 5 small screws on the bottom panel.
    • Lift off from the narrow end on the battery panel side. You may have to open the battery cover. The other end is hooked to the body. There are also 2 small tabs on the mid front side.
    • Remove the 2 screws on each side, total 4.
    • Gently separate the back panel and front panel. You do not need the separate the panels completely.
    • With battery in, power on and it will start up and the lens barrel will extend fully as it should.
    • Turn power off and it should retract completely and lens cover should also close.
    • Replace 4 screws on the side, and hand tighten.
    • Replace the bottom panel, wide end with hook and 2 small tabs on the mid front side in and replace the 5 screws, again hand tighten.
Ziellinie
26 weitere Nutzer:innen haben diese Anleitung absolviert.
Cherry
966 Reputation
5 Anleitungen geschrieben
95 Kommentare
I tried the fix TWICE.
After each re-assembly, the same problem happened.
Any ideas on alternative fixes?
With on-line repair service priced at $300 (July 2016), is there any reason to keep the camera?
jvbeaupre - Antwort
I tried the fix at least 5 times…same problem as Guide / jvbeaupre...
phwaeger - Antwort
It actually works, but only as long as I keep the camera disassembled. Once I put it back together again, the same problem re-occurs. It looks clean, but is there something in particular I should look for? Something that I should try to avoid "squeezing" when assembling?
Niklas James - Antwort
Hi Niklas,
had the same issue. I remove the panel at the bottom and it works for a while - but - as you can read, a workaround is less as a fix ( ;
Cherry -
Did you find a resolution? I just started receiving this error message and before I start removing screws and panels, I'd like to know if you had success. Thanks so much.
Carol Mitch - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 73
Letzte 30 Tage: 297
Insgesamt: 43,900
